I have a c-1 hooked up via XLR to phantom power supply, and the phantom power LED is on. The phantom power is then connected via XLR to a Lexicon Alpha interface. From there, all I can hear is buzzing when the mic is connected, and it doesn't record any sound. What should I do?
Sounds like your Phantom power supply may be defective. To be safe, 1st try moving AC plug for Phantom supply to another outlet as sometimes "sharing grounds" can be a problem. If this doesn't help, try using another phantom power source ...many PA mixers have built-in phantom power. If the buzz disappears with a new one, it will be a filtering issue (capacitors) with the old phantom supply.
SOURCE: Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
Nevermind, it does record sound but the buzzing overpowers it
