Apple iPad 64 GB 3G Tablet PC Logo
A
Anonymous Posted on Apr 20, 2014
Apple ipad A1396 on itunes mode how to unlock
3 Related Answers
peggyw1
  • 6 Answers
  • Posted on Oct 01, 2014
SOURCE: how can i get my ipad 2 out of recovery mode
I assume you did reboot. After that I would try to update again.
:) Hope this works for you.
ineedabin50249
Joe Stanch
  • 755 Answers
  • Posted on Jan 10, 2015
SOURCE: i have an ipad that ask me for apple id that was used to erase this ipad.how do i get pass this
you do not , it is locked to icloud and the real owner is the only one that can open it , look on youtube you will see what I mean
Jude24
  • 313 Answers
  • Posted on Nov 14, 2016
SOURCE: I have an apple iPad I disabled my iPad because I forgot my password , I try too many times , it is letting me know to connect to iTunes , i not understanding why . Thank you .
All of the Ipad interface is done through i-tunes. You have to connect there to do the setup or retrieve your setup. It doesn't seem to make sense, but that is the way Apple does it.
How can I unlock my iPad?
As a matter of fact, there are a few different ways to unlock your iPad. And using iTunes will be easier. Just follow below steps.
How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
For more methods, check: How to Unlock iPad?
My iPad was "reset all setting" and now it only display an usb cable and draws an arrow to the word itunes. It is iPad 16 GB Model A1396, FCC ID: BCGA 1396 and IC: 597C-A1396 How to return it normal?
It is telling you to connect it to your PC or laptop where you have iTunes installed. If you don't already have iTunes installed in your computer, you will need to download and install the iTunes software to it. When your iPad is connected, iTunes will synch and update it if you managed to erase the O/S or other necessary items. iTunes connected via the USB cable is even able to install or update the tablet's operating system. It's not just for music.
Your laptop or desktop will need to be connected to the Internet in order to download updated or original operating system. Just follow the prompts.
2answers
Ipad A1396 is disabled its sayes to connect to itunes but itune
The intent is to connect your iPad to a computer that is running iTunes.
You must have a current version of iTunes that knows about iPads and an operating system that can run the current iTunes. If your need to upgrade, be sure to install the OS first before your install the iTunes.
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
How to unlock ipad 3
As for unlocking iPad, there are several ways you can resort to. Just follow one of them as below shows.
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
How to unlock ipad if I forgot password
If you forgot iPad password, there still are several methods to unlock iPad. Here take one of them as an instance.
iPad Air
iPad mini/iPad pro
2answers
Ipad A1396 is disabled it says to connect itunes but itunes does not connect or recognise it
This is a job for an Apple Genius. You will have to make an appointment online with a local Apple store.
Download link for iOS 5
you need to connect your iPad to iTunes on a computer
and update to iOS 5 there
download-link-ios-5-ziidwqfjzh12fiagolk42ia4-3-0.jpg download-link-ios-5-ziidwqfjzh12fiagolk42ia4-3-2.jpg download-link-ios-5-ziidwqfjzh12fiagolk42ia4-3-5.jpg
1helpful
2answers
Forgot reset password
you can reset your iTunes password from the iTunes web site, and the associated em address. and restore the iOS device on your computer with the iTunes app
Ipad air will not unlock
Try below steps to unlock your iPad Air.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
