Had a Sears technician come out to service the freezer. He told me you just have to replace the thermostat. I did that. The freezer maintains the proper temperature but does not stop running.
Do you know what design temperature is for that freezer? Some are meant for 0 degrees others for -10 or 15. I would say you are trying to maintain -10 for a food freezer and trying to keep ice cream frozen. Ice cream freezers need to be colder than food freezers. I know it sounds dumb but look it up. Check the door gaskets to see that there is no leakage and the surrounding area should be no higher than 75 degrees, (otherwise it\'ll run all the time). Hope this helps and good luck.
SOURCE: True freezer T-35F shoudl it be running hard all the time?
Check and clean condenser regularly, check thermostat set at 2 or 3 and check fan is working ok. Apart from that, check the evaporator isn't frozen solid with ice.
