Question about Maytag Neptune Washer
Washer started and then stops mid cycle
Started yesterday, set dial to normal settings and washer filled and started but about half way through it stopped and now it runs for a minute or two and then stops, when you restart it runs for 10-20 secends then stops, let it sit for a few minutes and then it'll run for a couple of minutes then stop.
    Top Expert:
  • Maytag Master
  • 6,289 Answers
Sounds like the motor is bad.
Posted on Sep 24, 2018
    Habit-Forming:
    New Friend:
  • 11 Answers
Try unplugging it for a minute and plug back in, that should reset it.
Posted on Jan 09, 2018
3 Suggested Answers
6ya staff
SOURCE:
TomZS
  • 220 Answers
SOURCE: Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Posted on Sep 03, 2009
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: Washer will fill with water then begin the wash
Hello, walter
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Nov 01, 2011
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
My Kenmore 400 washing machine is relatively new and has always worked well, until yesterday when we were washing a load like normal and the washer just stopped working after filling full of water. We've...
My would fill up with water then not spin. Then it would do nothing. I called a repair man out it was the safety switch. You remove the top where the dial is and to the left side of the machine you will see a black connector, it plugs into the switch, the swtich will have a green ground wire. I replaced the switch it works great. The switch is $8 on amazon.
Feb 19, 2011 | Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Bought new freezer, came yesterday. It hasn't stopped running. What do i do ?
Hi, Give the freezer 24 hrs to get temp set. Make sure the control dial is set half way.
Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Freezers
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Continous fill & No Spin cycle
Is there water running in all the time? If so turn off each supply valve to the washer to see which one stops the flow or sound. The valve on that line in the machine is not closing. Taking it apart and cleaning it may work but normally you can get a kit to repair these for just a few dollars and the complete valve assy which replaces both is not very expensive. You might be able to get a good used part off of another unit at a salvage yard. Most of them are the same inside and replace one another.
Feb 10, 2008 | Asko W6221 Front Load Washer
Washing Machines Logo
201 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
