SOURCE: Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
SOURCE: how can you test if sony grand wega lamp is faulty
hello if the lamp is faulty the bottom light will flash on the front of tv. the other way is to take the front cover off and check the lamp by eye. the wire inside the lamp will be burn't good luck
shaun
Testimonial: "hi thanks for your help i wiil try this."
SOURCE: replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
SOURCE: how do you install the lamp on a sony wega model
Hi,your part # is xl-2400 here's a video on how to replace it: http://www.youtube.com/watch?v=b31IYV3IYKs The instructions to replace the lamp http://guides.fixyourdlp.com/sony/XL-2400.php and where to find it : http://www.discount-merchant.com/Sony-XL-2400-Lamp-F93087500-Bulb-A1129776A-p/sony_xl-2400_f93087500_bare.htm
