Question about Hoover Nextra HNL 3166 Z Front Load Washer
Hoover washer HNL3166Z how do I open filter to check if blocked? thanks
How do I open filter to check if blocked? thanks
Model MTW5840TWO water will not drain on the spin cycle
Perhaps none. Have you checked to see if the lint filter is blocked? Usually, the lint filter can be accessed from the front bottom of the machine, often behind a small door. Open the door, open the filter (have a bucket available to catch water) and remove the blocking ball of lint.
Feb 21, 2016 | Whirlpool Washing Machines
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
How to block lan IP
IP filtering is a method used to block computers on an internal network from accessing the Internet. This is often used on critical machines on the network, such as servers. It blocks users from accessing the Internet to protect these machines from malware. You can filter IP addresses on your router using the administrator console provided by the router's manufacturer. Once the block is set up, each user machine listed in the filter settings will no longer be able to access the Internet.
Open your web browser and type in the IP address for your router. For most default settings, the IP for the router is 192.168.1.1. Enter your admin username and password. If you have not set them up, try leaving the username black and the typing "admin" for the password. Click the "Security" tab at the top of the window. This opens a new console screen. Within this screen, click the "Filter" link. A list of text boxes is shown where you enter the IP addresses you want to filter. Enter a range of IP addresses you want to block. You can enter one IP address or several. Click the "Save Settings" button. Hope this helps.
Dec 07, 2012 | D-Link DSL-2540B ADSL2/2 Modem with 4-Port...
It says to Check the air flow
Open the cover. At some ends there will be 'filters', to clean the air entering the projector. If these filters are blocked with dust or lint, air flow will be blocked.
Clean any dust from these filters. Close the cover and check whether your problem is solved.
Sep 14, 2011 | Hitachi CP-X251 LCD Projector
Water not Dispensing from tap when pressed
Hello
Check that the water filters are not blocked if not the check that the solenoid valve is opening or the switch is working
Thanks
Jun 08, 2011 | Westinghouse Refrigerators
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
ZWF1630W
I trust that the drum can be turned by hand.It seems like the filter is blocked you will have to drain the water and remove the filter check that it is clean and the pump is free,with filter out put to spin or drain and see that the pump blade is spinning if not then something is jammed in pump try to free and then replace filter and check for leaks.Check also drain hose not kinked or drain blocked.Hope this helps.
Apr 28, 2010 | Zanussi ZWF1630 Front Load Washer
I have a Kenwood KDW12ST3A that intermittently shows E1 Thank you in advance for your help.
Hi
E1 means no inlet pressure. Sometimes fault code shows if machine takes too long to fill. Kindly check for blockage in inlet pipe. Also check if water inlet is not filling and check if the water outlet valve is opening and there is sufficient water pressure.
Please do rate the solution as "FixYa" and revert for any clarifications.
Thanks
Rylee
Apr 16, 2009 | Dishwashers
Hoover Nextra HNL 3166 Z Front Load Washer Logo
59 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
