Fender Telecaster Squier Electric Guitar S/N CY04124006 with Krate amplifier How do I obtain value and year of production
Cy04. The first 2 numbers are generally the year of manufacture so yours is 2004
as for value it depends on lots of factors ie condition model etc but generally base model squires can be purchased new from as little as 100-$200.
so unless yours is something special It wouldn't be worth much.
If you think it is worth more then u need to do ur research
SOURCE: hi i`m looking for a site somwhere to date hohner
Try here:http://www.jedistar.com/jedistar_vintage_guitar_dating_h2.htm
SOURCE: I have a Fender Telecaster guitar and a Crate amp that cuts out i
The next time it stops, unplug the cable from the guitar and touch the tip of the connector with your finger. If the amp hums, then the amp is still working and the problem is in the guitar. If there is no hum from doing this, then the amp has am intermittent.
Try this before it fails to see what to expect in the way of the hum from this test.
Common problems with the amp are OFTEN with a broken input connector or bad switch on the preamp output jack if it has one.
There are MANY other things and without troubleshooting it is hard to steer you to a fix.
SOURCE: I recently had my fender
Spray contact cleaner into the back of the control and work it up and down many times quickly to clean it and go get your money back from the shop.
