Question about Maytag Neptune Washer
Water flows out door while in use - Maytag Neptune Washer
    New Friend:
Check the door gasket/seal for damage. Check to see if the door's mounting brackets are loose by lightly moving the door up/down. Also check the level of the machine to ensure that the frame is not twisted.
Posted on Apr 22, 2014
6ya staff
SOURCE:
Frigidaire professional refrigerator
Sounds like you have a problem with water valve/triple solenoid assembly. It controls the flow of water to the door and ice maker. I believe it comes as a complete unit.
Dec 28, 2013 | Refrigerators
Icemaker not working, water works fine, freezer working as designed
If you model has water n the door, check to see that it is flowing quickly.
If it is flowing slowly, or is not flowing at all, then it is likely that you have a clogged water filter.
The filter is usually locataed in the upper right hand side of the fridge, after you open the door. Or on the bottom left side with the door closed.
Good Luck!
Jan 30, 2010 | Refrigerators
There are two water lines coming out of the back of the fridge. One of them appears to be an over flow. There is another over flow line coming out of the door. The problem is that there is no water going...
Good day,
What you refer to as an "overflow" line or lines, is actually the water line that runs from the water valve to the bottom of the freezer door.
It has failed.
In some cases it can be mended with the proper tubing and fittings, however....
I suggest you go to an appliance parts house with the complete make and model number of the machine.
They will be able to bring up an exploded view of that area, and supply you with the proper parts.
P.S. This can occur if the line in the freezer door has frozen.
You might consider unplugging the machine and leave the freezer door open to thaw out. 12 hours minimum.
I know, a real pain, but that's the cost of this particular problem.
Nov 29, 2009 | Kenmore Refrigerators
Water flows out the bottom of freezer door when handle depressed
not in the door , just pull the kickplate off and you going to see waths wrong the tube is unpluged there
Jun 17, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water dispenser not working
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
May 31, 2009 | Amana ARS2464B Side by Side Refrigerator
Kitchen aide ksrg22ftss fridge wont make ice and
check your fill solenoid located at the bottom back of fride the valve may have a verry fine filter inside the valve ether clean it or replase the valve valve cost aprox 20,00 thanks from gilles
Mar 15, 2009 | Refrigerators
Frigidaire water leaks
I suspect that when the water valve was replaced, that the plug's were reversed that provide the power to the valve. Exchange the two plugs on the water valve and you may find the problem is fixed.
May 25, 2008 | Frigidaire FRS26H5AS Side by Side...
Slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Apr 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
No Water
You may have a problem with a frozen water line inside the freezer door.  There is a heating element that keeps that water line from freezing but it apparently has failed.  It is not serviceable.  The whole door has to be replaced.
Dec 27, 2007 | LG LRSC26940ST 36" Side-by-Side...
Washing Machines Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
