My tv has mostly red and blue colors. The skin color is always pink and the plants and trees have a strange blue-green color. Lemons look orange and there is a lot of lilac in every picture. I tried to adjust the hue to green but there aren't any hue adjustments in my tv's picture menu although the manual shows that there are. Is there any other way to adjust the hue? Thank you!
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
SOURCE: no blue color, green replaced blue, white is yellow/green
If the set is hooked up using Component cables (red, green, blue), then check to make sure the cables are hooked up correctly, and not defective (change them out). If the color problem remains, then the problem may be in the Optics block of the television (which is not unheard of in this unit).
If the menu of the TV displays blotchy discoloration, and the discoloring is the same for every input on the tv (stationary), then it is the Optics, and the optics need to be changed. It is not the easiest job in the world, and the block itself is quite expensive, although the unit my be under an extended warranty from Sony. Contact them directly to see if you can get any help (cost or service-wise). Hope this helps...
