Ice dispenser starting dripping or leaking water then the ice maker stopped making ice.
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
SOURCE: Frigidaire Ice Maker not working
I have a Frigidaire side by side refrigerator freezer MRS20WRGW0. I had the thermostat-defrost replaced yesterday. Now the ice maker isn't working, doesn't have water in the "tray" part that makes ice, but does still dispense water through the door. What could be causing this problem?
