Neptune gas dryer: on sensor cycle (always use), seems to 'get stuck' at about 11 minutes left in cycle. I'll check the load and it's still damp somewhat & is cool to touch (instead of warm). After leaving off for a few minutes, I'll start the cycle from beginning again-I can hear the gas ignitor kick in and then it seems to finish the load as normal. Sensor issue or what?
SOURCE: Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
SOURCE: 99 minutes
It sounds like you may need a new timer. Has water or anything gotten into the timer. This could be causing a short or faulty reading in it.
SOURCE: Maytag Neptune sensor and time drying settings
Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
the dryer worked perfectly. V
SOURCE: Dryer switches from sensor dry to 17 min, on time dry it just doesn't heat up
check your ignitor id make sure the vents cleaned as well
SOURCE: dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
