SOURCE: Canon SD550 Digital Zoom Not Working
Digital Zoom is best ignored in any camera it simply blows up a section of an image already taken, You can do that far better with an image editor in the computer. As for the Optical Zoom - it does indeed seem to be repair time- As it is only a year and half old- may be Canin will be sympathetic and offer a cheap swap out.
SOURCE: Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
SOURCE: Powershot A620 Zoom Lever
Remove your batteries and look inside the battery compartment. Notice that there should be three small phillips screws at the bottom of the compartment. Tighten up all of these screws.
SOURCE: i purchase a canon powershot A1100 IS in dec. and
There is a one-year warranty on the camera if you purchased it new. Contact your regional Canon support facility, and they will be able to give you your options for getting the camera repaired under warranty.
