MY CLOTHES COME OUT STAINED FROM THE WASHER. SORT OF YELLOWISH LARGE STAINS.
SOURCE: problem with front load washer
Are stains a brown rusty color? If so, this may be an indication that the rear drum bearing is going bad. The bearing itself cannot be replaced. You will need to replace the entire back shell of the wash tub. Hope you have a warranty. This can be an expensive repair. Let me know if this is the case.
SOURCE: Dark brown stains
the rear tub bearing is shot and will have to be replaced you have to replace the whole rear tub. the brown marks are coming from the spider shaft assembly its rusted out you will have to replace the whole stainless steel tub.
http://www.applianceaid.com/frigidaire_frontload_washer.html#noise
SOURCE: front loading washer leaves stains
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
SOURCE: black marks
To eliminate possible bearing failure, spin the drum by hand and see if u can detect any rumbling noise or strange nioses coming from the drum, if u can then it is probably grease that is coming from the bearings. The other possible cause is an effect called ****, this is a result of washing at too low a temp, this causes a build up of dirt and grease,leading to the sort of prob that u are experiencing The thing u should do is to put the washer on at a high temp with powder in but no washing and do a full wash . This is called a maintenance wash, and should be done at least three or times a year depending on how often u wash more frequently if u do a lot of washing. Clean the door glass and rubber seal as thoroughly as u can ,and remove as much sludge and dirt as poss. This should help with your prob. Plz rate my solution. Thanks.
SOURCE: the washer is leaving a dark stain on all of my white clothes
the dark stains are caused by mold build up on the boot of the washer, the e70 may be a pump error. you need to wet a cloth with bleach and then wipe of the mold builldup on the boot, this should solve that problem.
