You can buy a new block and you don't have to replace the whole harness if the wire just burnt at the block,you can cut it,put on another wire connector and reconnect it to the block with the cord,make sure when you're done all the nuts and connectors are tight so this doesn't happen again and use the metal cord bracket,if it's not on your cord buy one,it holds the cord in place so when the dryer moves it holds the cord in place,if you don't use it the cord could cut on the metal frame and the wire connectors on the block will come loose from the cord moving or vibrating with the dryer running
SOURCE: Electric Dryer
If your dryer came with a 4-prong plug, do not change it. For the very reasons you quoted with the article, you may screw up the 110v accessories required of your appliance (like the clock or digital display). It is best to change the household outlet to a 4-prong type. Just make sure your wiring is correct. You will need a neutral on the 4th leg, which means you will probably have to run new wiring from the outlet to the distribution panel.
SOURCE: Bought LG DLE2532W Dryer it in Canada, need to use it in Europe
I have Electric Dryer Samsung- and I jsut have transformator with 2 separate 110 volt that together are giving the 218 volt. this is strng one for 5 8 00 watts. only the problemI hvae now is that I am having this erorr sighn - power inturaptions.
SOURCE: LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
SOURCE: How to connect a new dryer plug
Helo,
Yes you can reconnect it to the original place and everything will be fine...
Heatman101
Testimonial: "That was fast!"
SOURCE: My LG dryer had a 4 prong cord and my new house is a 3 prong
Well a dryer works off of 240 Volts. It splits that up. The light in your dryer uses 110V but the heating elements use 240V. The motor which won't start uses 110V and the controls use 110V. There could be a couple prolems and of which it could be. You need to get a meter and check that both leads are getting 110V from each hot lead to neutral. Also when you switch back to a three prong, the ground is no longer separate and you need to jumper the ground to the neutral terminal. (When you have a four prong cable the ground is separate for the fact that its safer). Even if the circuit breaker is on, I would check that each terminal of the breaker is putting out 110V to ground (If so it needs to be replaced, its simple to do just wire it like the other one, and turn off main power to replace it so there is no power to the buss bar its attached to. Just be careful not to touch the main feed wires to the panel as they are still powered). If none of this pans out, it could also be that your dryer needs that four wire plug (I would check with your manufacturer). Either way, if your dryer worked before it shouldn't be a dryer problem now
