SOURCE: install ATK0100 driver first
You will need to install the update first, I found 3 versions of ATK0100. You can try all versions if you like starting with the latest version. Just remember to create a restore point before you install any of the drivers that you want to upgrade just in case anything goes wrong, you can go back to an earlier time when the system is working OK.
Latest Version :
Asus ATK0100 ACPI Utility 1043.2.15.61
Link :
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Asus-ATK0100-ACPI-Utility-104321561.shtml
Older Versions :
ATK0100 ACPI UTILITY v 1043.2.15.56
Link :
http://www.techspot.com/drivers/driver/file/information/7257/
ATK0100 ACPI UTILITY v 1043.2.15.49
Link :
http://modrv.com/other_devices/asus/2869prog.html
Note : If the links will not work, jsut copy the link and paste it to your web brower's address bar.
**For creating restore point, you can just go start>all programs>accessories>system tools> System restore. Just choose create a restore point and specify a restore name.
**The Drivers that are available are for Windows XP
SOURCE: error message can' t open acpi atk0100 kernel
maybe it's installer format cant be read by your notebook. try to look other driver installer format.
