SOURCE: ERROR CODE SC101
Definition Symptom Possible Cause
SC101 Exposure Lamp Error
The scanner has scanned the white
plate, but cannot detect the white level.
• Defective exposure lamp
• Defective exposure lamp stabilizer
• Defective exposure lamp connector
• Unclean scanner mirror
• Scanner mirror out of position
• Defective SBU board
• Defective SBU connector
• Lens block out of position
• Incorrect position or width of white
plate scanning ( SP4-015
SOURCE: Ricoh Afico 2075 sc551 error code. the thermistors
Press total clear (yellow key) , 107 and press and hold the clear stop key (orange key) more than 3 seconds, shut off and on the copy.
Good luck.
SOURCE: my copier is ricoh aficio
That message is related to the scanner.
Probably the scanner lamp is dirty and the white bar under the glass.
You have to remove the glass and clean it with a dry cloth.
See you
SOURCE: i have a copier ricoh 2075 and the proble code is
you either have an invaid ip address or your nib or controller board is bad
SOURCE: Ricoh photocopier 1055 code sc101
for sc101
Exposure lamp error
The standard white level was not
detected properly when scanning the
white plate.
