Euro-Pro 0.7 Cu. Ft. Convection Toaster Oven Logo
Philip Clark Posted on Apr 22, 2014
Need replacement parts
Need to replace the rotisserie shaft and holders
John Krueger
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Dec 14, 2014
John Krueger
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
2057
Points
Need replacement parts for the rotisserie on my module to241r. toaster oven.
Model No. T0241B
I can't find parts other than knobs for this brand. They don't support this product very well.
Model T0241B
Not finding parts for this brand Euro-pro Bravetti. It is probably made by another manufacturer.
2answers
2answers
BTOBR0010 replacement part
Need replacement spit and forks for WGP rotisserie
Hamilton Beach 31197 blower not working
There is no fuse. This is not an easy repair. I replaced mine which had an open winding. HB tried to make this unit so it could NOT be repaired, but of course it can be if you want to spend the time. The motor is part of a metal duct assy which also holds the rotisserie motor. It is RIVETED to the interior wall of the oven. The fan motor is a DUAL shaft C-Frame shaded pole 120 VAC ~ 3000 RPM ~ .5 amp motor which is not very common. The thermo on all these units is also inaccurate as the "sensor" is simply a metal plate screwed to the top right area of the oven interior. When I replaced my fan I also put in a new REAL oven thermo with a 12" sensing bulb which I mounted inside the oven as it should be. It took some searching to find these two parts. I have all the instructions and can post images if you want to tackle this. I did because the oven is large and the replacement model (31100 for $69 at Wal-Mart) has 1.5" less height and it uses the SAME parts with the same design flaw for the thermo. The retail cost on the parts for this job are ~$160, but I got mine for $15 total. I paid $48 for this oven years ago at Sams.
I bought a Euro Pro TO242RW convection oven and Rotisserie. No manual or rotisserie spit. were can i get these things. Thank you.
Have you tried to find the Euro Pro website to look there? Have you searched on the internet using Euro Pro, model,and the word manual because there are sites that offer manuals on products. And the same thing for the rotisserie part. Maybe doing that will give you leads to look further if need be.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
2helpful
Lost instruction manual for Bravetti Model#TO285 toast/conv.oven
The same unit was marketed under the Euro-Pro name, with the same TO285 model number. The manual, as a PDF, as well some replacement parts are available at this link:
http://www.euro-pro.com/europro/default.aspx
Hope that helps.
Top Euro-Pro Toaster Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
vince
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
