Panasonic NV-MD10000 Camcorder Logo
Posted on Apr 22, 2014
Capturing and editing via 16:9
I try to shoot using the cinema mode. but when I capture the video to Edius it appears 4:3 ratio. After capturing I check my timeline and put my settings to 16:9. But I saw it smaller than the original. Only it measures the safety frame from the monitor of Edius. Can you help me solve this problem of mine. Thanks . . .
  • Sampath
    Sampath Apr 24, 2014
    Their is no 16:9 video recording option in Md 10000 camera.
  • Sampath
    cinema mode record 4:3 ratio adding black bar.u can scale video or use the 4:3 editing sequnce
2 Related Answers
Anonymous
  • 473 Answers
  • Posted on Sep 06, 2005
SOURCE: Help - Capturing Video from a DVD-R Disc
A new version of Ulead DVD Movie Factory 3 claims to let you edit this DVD material. See if this helps you out.
A
Anonymous
  • Posted on Apr 08, 2008
SOURCE: capturing DV
same thing for me any help ?
Is that this card(canopus acedvio pro version) any problem with windows 7
MPN 770-10116-900
Adapter Type Video Capture
Interface with Host PCI
Video Input Composite Video • i.Link (IEEE1394)
Video Output Composite Video
Platform PC • Mac
Hey no problem....It is best for Video capture...the datails are this.... i still useing it.........
Technical Features
Audio Support Stereo
System Requirements
Operating System Apple MacOS 9.x or later • Microsoft Windows 2000• Microsoft Windows XP Home Edition • Microsoft Windows XP Professional
Warranty 3 Years
Included Accessories 1 x Firewire (IEEE1394) Cable • Composite to S-Video Cable
1helpful
3answers
How can I transfer my 8mm tape to my computer? I need to have the film on a flash drive or dvd.
Assuming that you want to do your video work later (editing,DVD burning)in your PC.
1.Your PC must have video capture device(either built-in or add-on).
2.Properly set your video editing software to able to capture video form your device.
3.Connect your camera to your PC in regular manner,like when you connect it to your TV.
4.Have your camera in PLAYBACK mode.wind the tape to the beginning of the footage you want to capture.
5.Open your editing software.turn on capture mode.
6.Start capture.At the same time,start playing back the footage on the cam.
7.When all footage were captured,click stop capture.
8.Start your editing work.
9.when complete,save it to some uncompressed video format like *.avi for later burning to DVD or converting to other format.
For beginners,I recommend Windows Movie Maker video editing software that should come bundled in almost every computer.It's fast,simple but effective enough for home-movie work.Once your project is completed,save your movie in original .avi format for later burning to DVD,etc.
BTW forget the old-school Linear Editing (on the tape) thing.It's slow,complicate and much less flexible than Non-Linear method.
How can i edit the video if i finish filming
Assuming that you want to do your video editing in the PC rather than on the tape.
5helpful
5answers
DVStrom-RT and Edius Pro 3
sn. 846007-6DVJQSNHVSWXOYCR
Activation Code .....?
My picture size keeps changing from 16:9 widescreen to "auto" (4:3)
it is not fault of ur camra dude, it is fault of software ur using to capture and editting. ur software has preferece option incapture mode go inti it and give him command to cap in what aspect ratio u want
I cant find the webcam icon
Use ACER Arcade application.
From User manual:
"Acer Arcade allows you to capture and record video clips from other external
devices, such as a DVD player or camcorder.
Click Capture Device on the video page and then select the source you are using
for your video input. There is a choice between "S-video" and "Composite."
To capture a video clip, you then need to click the red record button in the
onscreen controls.
The destination folder can be set from the "Settings" menu.
Clicking on Advanced and selecting Settings allows you to set the quality of the
video captured. You can choose from "Good," "Better" or "Best." Selecting a
higher quality results in a larger file when capturing video clips.
Snapshot
Snapshot mode is available in Cinema, Video and TV modes. This function can
be used to capture the onscreen image at any time."
Editing
dear jose thomas
Just trying using a canopus 4.0 for your ACEDvio ..it compatible with your canopus DVstorm
and your problem can solve with a correct codect or using edius 4.0 to capture your video
ok, post in me back
thanks
cropp
Viewing in the software two monitors
your software is in warranty. And your English is excellent. It is Canopus Edius's problem, il n'est pas le votre. Allez-y a
http://www.canopus.com/ pour demander qu'ils vous expliquez ce qui vous avez besoin--je crois qu'ils seront nouse assister vitement.
Si vous parle avec une personne qi apparaisse ignorant, demandez parler avec son superieur.
Bonne Chance
2answers
Can my camcorder work with imovie and if so how do i get my computer to get download my video?
Open iMovie and set it to capture DV. (Click the camera shaped icon opposed to the siscor scissor shape) When you see a blue screen that says (camera connected) and the image pops on screen of image from tape on camcorder set in play mode, you hit the import button and it begins to capture digital movie using DV compression of whatever you have on tape. You should be able to control your camcorder with the video controllers underneath the project window to make selections for the in and outpunts on the tape you wish to capture. Then switch to edit mode by clicking on the scissor button and import the movies you just captured or use them from the clips menu, etc. renedr movie back to tape, if you wish by clicking back and forth from edit mode (scissors) and capture mode (camera silo) and render to and from tape.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
