Each tv remote has a code list....you must find the code that corresponds withe the Brand of tv and enter the code then ALL the buttons will function properly
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]..
How old are the batteries in the remotes? The on/off signal from the remote is the same. There is some lattitude in the IR reciever module for what it accepts. Low battereis may be shifting the signal's frequency or light intensity enough for it to not be recognized.
If sunlight is failing on the sensor or the remote's IR emitter, that can cause interference. Other IR devices can also interfere with the IR signal such as a "Remote Extender" being used for something else.
It may sound odd, but if your remote was working one day and not the next- was the room rearranged? If so, look around for possible sources of interference blocking the beam from the remote, or shining or reflecting light onto the IR reciever module in the set.
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes. Power Scan 1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #) 2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once. 3.) Press the channel up button once per second until the TV turns off then press pound (#).
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
