During the dry cycle, the dryer beeps (not the beep, beep, beep, finishing alert, but a beep with pause before the next beep) about 10 times before stopping. Turning of drum is uninterrupted. I did not see any explanation in manual under troubleshooting. There is no Message where the display shows number of minutes remaining in dry cycle.
SOURCE: F2 My washer freezes during mid cycle
"F02" is a Long Drain error code, which usually means you have an obstruction in the drain pump, drain lines, or the drain pump has failed. If the drain pump will not function, the washer will not complete, or restart a cycle. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Sometimes you may also get a "SUD" error in conjunction with this error due to the detection of air in the drain pump (lack of water flow). If cleaning the drain pump reservoir, and checking all the drain hoses does not correct the problem, you may have a failed drain pump.
Replacement pumps can be purchased on line at searspartsdirect.com, appliancepartspros.com, repairclinic.com or pcappliancerepair.com. All these sites offer competitive pricing so shop all of them for the best price.
If you have any questions about this repair please let me know. I hope this helps you.
SOURCE: stops and beeps during rinse cycle.
Could be blockage in pump. if its used more than 5 times a week sounds quite worn in other ways if not ..go repair
SOURCE: Error Codes"5ud" and "02" and "F"
The two error codes together indicate you have something restricting the drainage system. "F02"is a Long Drain error code, "SUDS" occurs when too much air is sensed in the drainage system. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
SOURCE: F1 beeping pauses the washing cycle.
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: During any washing cycle the washer stops and
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
