Green light keeps flashing
SOURCE: Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
SOURCE: mitsubishi WS-55513 won't turn on
from what i know thru extensive research.....and i mean alot the dm board (as in the whole thing) is not all bad its thecapacitors on the dm board that are supposably cheap O'z if you know what i mean. there should be 4 of them. you can buy the replacemnets from radio shack for about 8.50. if you know someone who is handy with a soildering iron, or a freelace electically type then ask them if they can put the new ones on for you. the correct one you need are -40 degrees to +85 degrees Celceus...tolerance +20%, now this is important 1000microfarad.... now these capacitors cant be less than 16V they can be over but not under.... typical brand to get is xicon....you have to remove the dm board which is in a metal shield once the back part of the television is removed you will see it cause it looks like it should be in a computer. but apparently this is typical and its a very simple fix but everyone that is capable to fix it want to bend you over and do you dry....mitsubishi should be ashamed of themselves for not correcting this themselve and offering help with cost.. hope this helps guys!
natalie
SOURCE: Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
SOURCE: i recently was given a mitsubishi ws-55511 55 in
First you can try pushing the reset button located on front of tv where power button is located. If that fails to correct the problem then I would suspect the DM module has failed. They are not available for replacement. Some shops rebuild them by replacing the defective capacitors with some success others might send it to a company such as PTS to be rebuilt also with some success. Repair prices will vary from 275.00 - 375.00 depending on your location
Testimonial: "thx for the help "
