Zyxel P660HW-D1 Router Logo
A
Anonymous Posted on Apr 22, 2014
How to disable the dns server of an n300 router
My provider asks me to deactivate the opn dns server for security reasons, but how?
2answers
Got a new router it won't connect error 51030 shows up how do i fix this
Your information is really helpful for me and accurate also. There are so many other information available on net but not correct or half information so appreciate your information. we also share too many information about the router support,
<a href="https://www.factonews.com/Netgear-genie-router-tech-support.html">netgear router support</a>, netgear router tech support etc. If you want to read or in a problem to solve issue regarding the router, you can search about factonews.
Belkin N300 - CISCO Clean Access Agent
All configuration can be done with the router GUI.
Firewalls: Server Side Having a server side firewall is the typical configuration on many systems. There is only one method for doing this, whether you use telnet or ssh: map a port to be forwarded to the server in the firewall router. It is not advised that you use telnet from the Internet for security reasons; that is usually why you have a firewall.Decide which method of connectivity will be allowed, and determine what port you will use to forward to this service. If there is only one server involved, you can use port 22 for ssh or 23 for telnet and forward them straight through to the server. But if there are several servers involved and they do not have public IP addresses, you will need to pick different ports on the firewall router and let the router forward those ports to the different internal servers.
How to open NAT
With Belkin you have the option of disabling Firewall, or setting up a Virtual Server. You must provide the port based on program / game requirements.
Almost forgot, it does allow for 1 IP in the DMZ. This is you best bet. Easy peesy, nice and easy. gl
How do you find the DNS server address on a Belkin Surf N300
The DNS server address comes from your Internet Service Provider. When you go to the command line and type in ipconfig /all you will see DNS Servers and their addresses there
10helpful
2answers
DNS Server is not responding
On your computer, Click on Start and then RUN and type CMD... on the black screen/DOS prompt type there FlushDNS and press enter, this will clear out the DNS and should work
1helpful
Linksy router
a DNS server stands for domain name service. The DNS server translatesnames from IP addresses. The internet sees IP addresses such as 209.235.250.53 but the DNS server provided by your ISP translates it for you into fixya.com. You should be able to aquire the DNS server information from your internet provider (ISP) hope this helps.
Laptop connecting but not my desktop
> Try changing and creating a new wireless network name.
> Try changing your security mode like WEP to WPA or vice versa..
> Try to update you drivers on your laptop then restart your computer before connecting to your network..
> Try assinging DNS ( Domain Name Server.) ask your router manufacture for the DNS that you could use.
> Make sure you typing the correct password for your wireless network..
> Make sure you disable WI-FI protected setup and on the router.
> Try to disable Anti-virus and Firewalls on you laptop.
1helpful
Cannot connect to internet
Make the Ip address similary to the router, example 192.168.1.25 should work.
SUbnet mask will then fill in automaticaly, just leave it
then Default gateway will be the routers IP. 192.168.1.1
the dns server would be the ip of your internet provider. I would leave it blank at first, see if it will work then. If not, then ask your service provider for it. If they give u a number, then you will have to go into the router properties, and change the dns and stuff like that in there aswell.
good luck
2answers
I cant get onto internet explorer it says dns error can you help?
Check out your internet connection and its settings, whether it is dial up or broadband oriented.
then you have to know about your ip address of dns server in the network setting places.
you just ping the ip address of dns server following as...
go to start, then run and type "cmd", and it shows the command prompt. type as following format.
ping 10.10.10.5 and press enter key.. this is the sample ip address only. if it gets reply, your dns server is ok. you can use internet. suppose, it wont comes, ask your service provider or support for another or different ip address of dns to check it out.
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
