Usage page Shows a page count for each size of paper printed, the number of one-sided (simplexed) or two-sided (duplexed) pages, and the average percentage of coverage. 1. From the Home screen, touch Administration. 2. Touch Information. 3. Touch Configuration/Status Pages. 4. Touch Usage Page. 5. Touch Print.
Shut down the printer and remove the power cord. Leave the unit off for a minute or two. Replace the power cord.
Press the "Power"
button on the printer. Hold down the "Select" button on the printer as
you turn the unit on. Continue holding the "Select" button until the LED
lights on the printer flash once and then remain on.
Use the up arrow to scroll to "New Maintenance Kit." Press the "Select" button to reset the maintenance kit counter.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Assuming your scanner is installed already, what you need to do is log into Windows Photo Gallery (Vista) and click on FILE at the top left. When the drop down bar engages, you should look for IMPORT FROM CAMERA OR SCANNER and click it. Then a new window will open up and you'll have to pick your device (HP Laserjet M3035). At this point check your settings, and make sure your scan is ready, then click on either PREVIEW or SCAN. Then when it is done scanning, you will have to go to the folder you saved it in to view it. (Xp Similar)
Load paper in tray 1. Print a few pages, as it's printing open the top cover, remove the toner, look at the paper in the printer. Does it have printing on it? If it does, the laser/scanner is working. It could be the transfer roller, it could be Hi Voltage Power Supply. Look in Print Quality Menu/Toner Density. Increase the density.
Open the rear door. Power on the printer. Watch and listen as the fuser rotates. Does the noise occur when the fuser rotates? if yes - replace it. If you still think it's coming from the toner, remove the toner, close the toner door. When the motors start turning the noise should be gone. Insert the toner and listen again
