Turn off the phone and pull the battery out. Put a small amount of alcohol on a cotton swab and gently try to clean the sim connectors. Put again your sim card e turn on your phone. After that, if the phone doesn't recognize the card, try with another simcard if possible.
First All Check: 1.Confirm whether same sim card is working in other h.s or not. 2.Make sure the sim slot is o.k. only try these two. 3.If all the above steps fails, check the SIM card connector pins for damage. if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD. u can make it jumper mean u can fix this prob with out sim card is for this contact. 5.take sim connector slight up by pin then cheak by inserting sim. 6.hot air gun on sim i.c. then cheak it. Last Option: IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service & Sim Office and Get the Duplicate Sim Same Your No From Office Oprator Problem will Solved Quickly
Hi.Insert another sim card to your phone and try.if this doesn't solve , clean the sim card slot connector.Otherwise you need to contact a mobile technician.And if another sim card is working in your phone and your sim card shows Rejected to every phone,then the last solution is to change another sim card from the particular sim card provider.Good luck
#7465625*228# = Activa lock OFF Type *#9998*627837793# Go to the 'my parameters' and there you will find
new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then
type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock,
type in 00000000 then it should be unlocked. Type in *0141# then
the green call batton and it's unlocked to all networks. This code may
not work on the older phones and some of the newer phones. If it doesn't
work you will have to reset your phone without a sim in it by typing
*#2767*2878# or *#9998*3855# (not tested)
It may not work in all phones, but with standard its working ;)
Using the sim card from your tracfone in another phone is possible if both of the phones are unlocked. This means that the sim card if inserted into any phone, that phone will recognize the sim card. If you place your Tracfone sim card in any other carrier's phone and it doesn't work you can call trachoma and they can unlock the sim card.
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Hi there, you may try to reset the whole software on your cellphone. Provided to back up all the necessary contacts, messages on your Cellphone. There is a need to update the software version of your cellphone to make it working again.
you just need to get a new sim card for these phone and make sure to transfer numbers to new sim this is basically a sim problem when they get use to a phone there parameters are eched into the sim and then they only want to work with that phone
