I ask a question click search up pops several search eng but i can not open have i closed something in the task bar at the bottom of my screen
SOURCE: I cannot get Taskmanager Option
hi try this if ur adminstrator
Click Start, Run and type Regedit.exe gizmo 1 (A) SOURCE: Opening of drives
I have seen this several times and it is brought about due to a virus that creates an autorun file (autorun.ini). SOURCE: my task bar don't show the tasks running
This problem occurs because the Fixccs.exe file generates some garbage keys in the registry, when you install the sp2 with security update 905749. SOURCE: search window opens when not doing a search
That is a sure sign of an infection. SOURCE: It seems i cannot find the SEARCH in the Start
press ctrl+alt+del for the task manager. and for the search right click on any folder or drive you will find SEARCH option there.
PLS REPLY
OR COMMENT. THANKS
Click on "Close Gadget." The search function is now gone from the sidebar; however, the search gadget is still installed on your computer for future use if you ever decide to re-add the item to your sidebar.
Right-click on the sidebar search gadget you want to remove, and click to select "Uninstall."
Click "Control Panel."
Double-click "Windows Sidebar."
Remove the check from the box next to "Start Sidebar when Windows Starts."
Click "Save." Now, the next time you load your computer Windows Sidebar will not start.
63
views
Navigate to the following branch:
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
In the right-pane, delete the value named DisableTaskMgr
Close Regedit.exe
In this file when you double click the drive, executes the file and in the autorun file exists any of the following: -
Microsoftpowerpoint.exe
smss.exe
.... or many others.
It is good thing that you have a strong antivirus which seems to have removed the viruses and therefore when the information file is opened, it does not find the executables it was supposed to run. That is why it asks for a program to open.
You can prove this by right clicking on the drive to see a shortcut menu and in this menu, the bolded menu will be the action taken when double clicked and the possibility is that you will find Autorun bolded.
To resolve the issue do the following:
1) Open My computer program or windows explorer.
2) Right click on the drive and open or explore it.
3) Locate the file Autorun and delete it. If the file is not shown, from the folder options choose show all files. This is because sometimes this file may be hidden.
Try double clicking the drives again to see if you get he same error.
NOTE: Many virus developers have made possible for people to install/run viruses in there own computers by simply double clicking the drives like flash disk.
go to the following link.
click on the "view and view hot fixes"
http://support.microsoft.com/kb/914450
First of all perform all the Windows updates.
Second, run your AV program, an antispyware, and hijacker programs.
Its going to be lenghty and tedious job, but necessary if you want to keep your information.
Another solution could be make a backup of all your data, and format and reinstall your OS.
Don't forget to rate this answer if it helps.
Why im on Ask not google?
click the three lines at the top right corner, settings, (a new tab will open), the 4th group down is Search, you're set to Ask, just change it to Google. Just close the tab, it saves the change instantly.
If you mean the home page, also go to 3 lines, settings, and the second group "on startup" select "open a specific page or set of pages" and then click Set Pages. hover over any pages you don't want to open at startup and click the X to remove, and in the box for Add New Page, enter http://www.google.com/ then click ok, and close the tab.
If you mean something else, let me know exactly what you want and I'l try to help.
Why do these ads keeping popping up?
If you're using IE Explorer, click on "Tools" (top right corner of screen - tool bar), put your cursor on "Pop-Up Blocker" (in the drop down window) and click on "Pop-Up Blocker Setting". Then, at the bottom of the window, set the "Blocking Level" at HIGH - which blocks all pop-up from showing up on your screen.
You can do it for other browsers as well ... e.g. Mozilla Firefox ...
click on Open Menu (the 3 horizontal bar on top right corner), select Options (in the drop down window), select the "Content" tab ... and check of the box (on the top) that says Block Pop-Up's, and then close.
Often pop-up's show up because your activity (viewing, searching, etc.) on the browser is tracked. Yes you can turn off tracking too !
This tracking info is used by "ads spawning" processes/apps to select which ads is displayed on your computer. So, you can reduce the amount of ad's by deleting cookies (particularly for these ads programs) every time you're done and close your browser ... just like you remove your (browsing) history, temporary files, cache information, etc.
When i click onto some search eng they will not open
Trying to get google on my browser
Remove ask search
How to Delete the Ask Search Engine
Click the Start menu and then select the Control Panel
Click the uninstall program
Look for and click the Ask Toolbar
Click the Uninstall button
If prompted enter your administrator password and click Continue
A dialog message pops up asking you to confirm your selection.
Click OK.
Wait for the Ask Toolbar to be removed
Click OK
when you see the uninstallation dialog box. Close and restart your browser when the uninstallation completes
Cant get rid of Ask
Create Menu tab right click
in the top of screen (toolbar) you will see a number of toolbar options select
the menu bar
This will
add to your screen toolbar File Edit View Favorites Tools
and Help
Select Tools tab then from the drop down menu Mange
Add - Ons you will see
Toolbar
Extensions Search Providers
Accelerators and Tracking
protection
You
can remove or disable them right click
on them select disable or remove some don't have the option to remove.
also
Get Rid of Ask.com as a Browser
Search engines come installed on Internet Explorer and
Firefox.
These search engines take over as the default search
engines.
Get rid of Ask.com from the toolbar after opening your
browser.
Interent Explorer
Open Internet Explorer.
Click on the arrow to the right of "Search." A
drop-down box will open.
Click "Manage."
A window will open called "Toolbar Options."
Click "Search" on the left-side panel.
A new page is displayed called "Search Options."
Click on the box that says "Set and keep Google as the
default search engine."
Click "Save." Close the window.
Firefox
Open Firefox.
Click the arrow on the left side of the address bar to
open a drop-down menu.
The arrow is right before the white space where you type the
search term.
Click "Manage Search Engines" from the drop-down
menu.
A window opens, showing you the search engines installed.
Click "Ask.com" to highlight. Click
"Remove" on the right side of the window.
After the search engine is gone, click "OK" to
close the window and delete "Ask.com" from available search engines.
Rid of the Ask Toolbar
Ask.com
is a search portal that attaches to your browser.
This toolbar is handy for quick access to the Internet.
If you do not use the toolbar often, you can remove it from
your computer.
Click the "Start" button in the lower left corner of your desktop.
Choose "Control Panel."
Click "Programs" and then "Programs and Features."
Find the "Ask Toolbar" item in the list of items
installed on your computer.
Highlight it and click the "Uninstall" button.
Click "Yes" to confirm.
Wait for the application to be uninstalled.
Restart your computer.
How do i remove the sidebar
On the Windows desktop, mouse over the sidebar and right-click on the search gadget you want to remove.
To completely remove the sidebar search gadget from your entire computer, follow the next steps.
Right-click on the Windows sidebar.
Click on "Add Gadgets" to open a window containing all sidebar gadgets installed on your PC, including the search gadget.
Click "Uninstall" again when a Windows notification pops up, asking you to confirm the uninstall process.
After you click, the program will automatically be removed from your PC and it will no longer appear on the listing of available sidebar gadgets for Vista
windows 7
Click "Start."
hope this helps
Please help! i cant install The Movies game on my computer. I have Win. 7. I click run and a compatibility issue about micromedia flash comes up but there are no solutions for the problem online. then...
Top Microsoft Computers & Internet Experts
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
