I have a Maytag washer that is about 11 years old. It is constantly unbalanced in the spin cycle. It is sitting level. The load size doesn't even matter. Clothes are sorted by weight. I haven't a clue as to what may be the problem. Any ideas?
Recently, the "LF" code has started to display and the soak cycle will not complete unless I ... Kenmore Elite Top Load Washer - Unbalanced Loads During Spin Cycly ... Would a bad outer tub literally cause the basket to become unbalanced?
? 1:21
https://www.youtube.com/watch?v=cVZIGhULzg0
Jan 17, 2014 - Uploaded by Carpe Diem
How to fix unbalanced high efficiency top load washer. ... I am having a MAJOR problem with unbalanced ...
it could be that soap has gotten to the stabilizer 'bumpers' that ride on top of the drum and allow them to slide instead of controlling the agitation or they may be missing. get the top off and clean the area that they ride on they may also need replacement- cheap fix
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Snubber ring that tub and spin basket assembly sits in is most likely worn. Very inexpensive part but extensive labor involved. I would suggest calling a competent service tech.
replace washer belt # 21352320 tilt washer back belt on bottom ...check for glossyness on belt and black residue causing belt to slip... make sure motor and pump pulley moves freely...
If the washer is truly balances (check with a level to be sure) you might just have an unbalanced load. When filling your machine with laundry, think of the tank as a big circle divided into four pie slices. Make sure you fill each of the four slices evenly. This should help,
Make sure the washer sits level on the floor and that the machine can't be rocked around due to uneven foot adjustment. The feet usually have rubber cups that cover the metal bottoms--one of the cups may be damaged or missing entirely. Hope this helps!
