Question about Hoover HTC243 Top Load Washer
Timer wont turn to next cycle
Timer wont turn to next cycle have to turn it my self still washes ok
    Top Expert:
  • Hoover Master
  • 9,098 Answers
That works unless you want to buy a new one.
Posted on Jul 15, 2015
6ya staff
SOURCE:
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Hello, our whirlpool keeps washing and washing, never getting to the next cycle. thx for help.
Hello there:
The most common problem with this is that the timer is failing and will not allow the machine to go to the next cycle
So what you are going to have to do is to take off the back panel and remove the wires that are attached to the timer (this is the part that you select the different cycles from ) better know as the timer ok?
then remove the knob and remove the timer and replace it than hook up the wires back into the new one and put the knob back on and the test the machine ok? and hopefully you will be good to go from here:
I hope this is very helpfull for you
Best regards michael
Dec 16, 2009 | Whirlpool Washing Machines
Washer will wash but wont change to next cycle it turns off
Most likely a bad timer. Not to difficult for homeowner to replace... Be sure to replace wires on new timer EXACTLY as they came off of old timer. Best to leave wires connected to old timer and move one at a time.
Hope this helps. Good luck.
Sep 11, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 90 series wont advance to next cycle
Yes, most likely but to be sure you can check voltage at the timer assembly 2 small black wires coming out of the timer.....
Jul 01, 2009 | Kenmore Washing Machines
My washer was working fine and now does not go through the cycles
the timer is not advancing by its self...defective timer replace..onthejob
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Washer wont complete cycle. its full of water and I cant drain it
if this a manuel timer,,you either stripped the ,,knob,,or you broke the timer its self...make sure that timer can be pushed and pulled,, pull ----on push is off
Nov 30, 2008 | Kenmore 24902 Top Load Washer
Wont pump water
If it did not pump at all I would say you had a bad pump. Try removing hoses and check for plug up. If there is no plug up, I would manually try to adjust the timer to see where in the cycle it does not pump. It could be a bad cycle timer.
Feb 04, 2008 | Hotpoint WMA30 Front Load Washer
Timer stuck on cycle will work if manually moved
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Nov 01, 2007 | Roper RAS8445KQ Top Load Washer
Hoover HTC243 Top Load Washer Logo
50 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
