SOURCE: user's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
SOURCE: Need Sharp EL 5102 Financial Calcualtor User Manual
I have a manual. Are you still looking?
Have the calculator too... but the display doesn't seem to work.
I loved that calculator - wish I had another.
Roger
[email protected]
SOURCE: i have a el-531x how do i cauculate fractions with it
Use the key marked [a b/c]
SOURCE: EL 531X Sharp - Help with calculations
You need a SHARP with Write-View display capabilities. The EL-531X is unable to show that. The Write-View calculators from Shard have a W, example EL-W516 followed by Write-View. Not to be confused with the W in EL-520W
SOURCE: sharp advanced EL-531x how to input number after number for stats
First you have to set the calculator in STAT mode, presumably Standard Deviation or SD. The display should show a STAT annoucer to the top. To enter values use the key M+ (or the key next to which is marked DATA. The screen displays the number of data values entered so far.
To get the statistics you must use the keys marked with x bar, n, Sigma x, etc.
