SOURCE: I have a 2001 Chevy Suburban 2001. the driver
Usually this problem is solved by opening the driver's door & looking for a broken wire. This wire usually breaks at the flex point of the harness between the door & frame. Carefully slice outer coating revealing hidden wires. The broken one is the culprit. Hope this helps. Good luck!
this control is controlled by the computer. make sure your a/c relay is good along with fuses. check the high pressure switch connection on back of compressor it may need to be put on a tech 2
Testimonial: "Thank you for the info. The wires were not making good contact on the compressor. thanks again"
