I am not aware that Uniden survellience systems pair with cameras other than a Uniden camera. Please provide model number of your Uniden system to help with a solution to your problem. I understand that GE Add-On Wireless Digital Color Camera 45256 will work only with a GE security system like Ge 45255
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
SSID is case sensitive. Make sure you select the correct security settings. Wireless Mode has to be Infrastructure. If it is still not working try upgrading to the latest firmware version
please do the following steps:-1-try to test power supply adapter in other equipment with the same voltage rating if it is ok connect power to camera and connect receiver video out to tv video in then select video input from tv input button.2-if power suplly not ok change it with other one from the seller.3-try it now if it is not ok return all the package. my best wishes.
Dear sir, U have 2 in one corder + cordless IR camera , & ur corder unit is working ur wireless unit is not working .. wireless transmitter is out of order needs repair if any one in ur area is doing this .
DEar sir, the small wireles camera has power output of 640 milliwatt & is so less for digital cards & DVR .. digital input can accept either 0 or 1 , & these wireless cameras are not having stable video , unless u use a strong trsnmitter , try the proces using a corded camera ..u will not see any snow effect . Out put direct to TV will be Ok for these wireless cams .
If the color LCD is not illuminated when the camera power is turned on, check the following:
* The camera may be in the wrong mode. Run this check to test the LCD:
1. Make sure the camera power is on (the lens cover should be open).
2. Press the Review button (top left) on the back of the camera.
The LCD will display the last photo taken. To exit the Play mode, turn the camera power off.
* The camera may be connected to a TV. Disconnect the camera from the TV and try the LCD again.
* The batteries may be weak. Replace the batteries or use the AC adapter. To save battery power, use the optical viewfinder when composing photos.
