Question about Hitachi Hammering
What oils do I use for hitachi hp 65a? - Hitachi Hammering
I have a PH65A Makita hammer demolition and it start working for about 10 seconds breaking and after that the hammering power slow and losses it's power hit even that motor keeps working, why?
first ordernumber 931848 lubrication necessary it has its working hours on it.
parts to change in priority
1 x 944-927 , 949457Z , 956-960 , 944-936 , 956-965 ,
999032 , 956-996 , 944-928
the important thing is that the machine is airtight at the front so as not to burn the O-rings through the air and incoming dirt friction look the orings good and if the lock bolt on the front feel not smooth replace that also and every oil seal you can find its different what should neccesary but that the tool runs with thick and dirt beaten oil . solvent clean the hard metal parts and replace if there are grooves on or cracks
Hitachi PH 65A Demo Hammer Parts
Feb 28, 2016 | Makita Hammering
I need a transformer for my resolv 65a monitor
Are you an experienced tech? In most cases (unless there is a defect in manufacturing) transformers are not a common cause for failure. If it blows the fuse disconnect the secondaries and see if it still blows the fuse. If it does then the transformer is likely the cause, if the fuse doesn't blow then the problem is elsewhere. If you have 120vac at the primary and nothing(or very low) at the secondary(s) then the transformer could also be at fault. If you have done this already and narrowed it down to the transformer, sorry I cannot help. I used service Samson but no longer am able to get parts. Good luck!
Jan 04, 2015 | Samson Audio Resolv 65a Active Studio...
Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Jun 14, 2010 | Samson Resolv 65a Main / Stereo Speaker
My tweeters are blown on my Samson Resolve 65a monitors...anyone know what I should get (and where) to replace 'em?
It might tell you on the back of the tweeter what rating they are. I should do a webserch for Samson spares and see what it comes up with.
Feb 02, 2010 | Samson Resolv 65a Main / Stereo Speaker
Samson Resolv 65a monitor repair
Its prob a dry solder joint problem.
http://www.gearslutz.com/board/low-end-theory/314545-samson-rubicon-r5a-problem.html
Jan 14, 2008 | Samson Resolv 65a Main / Stereo Speaker
Hammering Logo
111 people viewed this question
Top Hitachi Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
