My digital camera charges via my pc through USB and a green indicator light flashes during charging. I have had the camera for a few months and just ran into a problem with it yesterday. When I plug it into the USB to charge the indicator light blinks green but doesn't charge my camera, at all. Are there any troubleshooting tips?
SOURCE: digital camcorder problem
there a short line to the carbon wire of the function switch.....unfold the wire to loose the fold....and clean the contact of the wire using a pencil eraser slowly
SOURCE: Not charging
Try to turn on the Keyboard.
There's a switch in the right side of the Keyboard.
For more information download the User Manual at Logitech Site
SOURCE: Symbol MC35 refuses to charge
Try loading the latest Operating System files from Motorola. If that doesn't help you can try getting a new battery. If that doesn't work it will need to go to repair.
SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
SOURCE: Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
