Question about Fuji FinePix F470 Digital Camera
How do I reset my camera?
It is stuck on the date/time set view, and none of the buttons are working.
6ya staff
SOURCE:
Anonymous
  • 76 Answers
SOURCE: menu and ok buttons dont work. cant reset time/date
noway of skipping without having access to the buttons,im afraid but usually fault is caused by one of the buttons jamming and locking the rest of the keypad.pressing the buttons can usually locate the culprit as there is no movement.if you cant free the button will have to be brought to service.
Posted on May 13, 2007
Anonymous
  • 2985 Answers
SOURCE: Camera stuck at power on - says set date/time, but buttons don't respond.
This is a firmware failure. Fuji Technical Support need to know about this. a replacement may be possible.
Posted on Jul 19, 2007
Anonymous
  • 3 Answers
SOURCE: Button don't work
One of the buttons is constant presset in.
Under the button is a metal membrame, sometimes it happens by to mutch force the membrame is defect, it doesn't popup again.
Try to find out witch button doesn feal good anymore, can you work without it ?(for example left macro), open camera and remove membrame.
LKet it repait by fuiji ? a least € 100,-.more than new....
Posted on Nov 15, 2007
david
  • 244 Answers
SOURCE: camera turns on but it does nothing.
The ribbon cable for the buttons has either come out of its socket because it was not locked down (does happen) or it is broken and will need to be replaced. Fuji will not send out spare parts but will fix it for a price. Last quote I got from fuji to fix the keypad ribbon on an F470 was £80. check ebay for donor camera
Posted on Jan 25, 2009
david
  • 244 Answers
SOURCE: says date/time not set but wont let me set the time or date!
Broken keypad ribbon. It's because the keypad ribbon is folded over twice and the creases split over time. have a look at my tips page for this problem. It won't help you much I know and the only solution is a replacement membrane.
Posted on May 04, 2010
How do I remove the date stamp from all my holiday pictures taken with my DMC-SZ3
The date display option can come from your camera or the software programme you use to view. Start with the software and disable the date & time display function. If this doesn't work then go into the camera menu and in the display setting change the date & time to either disable or none.
Oct 01, 2014 | Panasonic Lumix DMC-SZ3 Digital Camera...
Won't take a picture and keep the time in the memory
You have a button that is stuck or the battery has an issue.
Feb 01, 2013 | Wildgame Innovations IR 2.0 Digital Game...
Sony cybershot dsc-w330 functions buttons does not work
Remove the battery and the memory card, press and hold power for 60 seconds this should remove residual voltage and reset the processor ic, if there is no change the systems controller board has failed, cheaper to replace camera.
Jun 09, 2012 | Sony Cybershot W330 Digital Camera
I have a Kodak Easyshare M1033. When my camera turns on it wants the date and time set and none of the buttons work!
HELLO SIR
turn it on , Press Reset Buttonù
turn it off , still pressing The switch on button 10 seconds
It works for me
Aug 29, 2010 | Kodak EasyShare M1033 Digital Camera
How do I set date and time
1. Press MENU to enter SET UP menu.
2. Press right or left arrow to reach the settings.
3. Then go on to view the menu
4. Find Reset Camera Settings.
5. Reset your camera.
6. Turn on the camera
7. Date/Time settings will appear.
8. Set your date/time.
Jun 03, 2010 | Kodak EasyShare V550 Digital Camera
Can this camera be RESET? Camera Stuck in Clock set mode.
If you are familiar with camera repair then apart camera and check navigation switch board is intact with main board of camera.
That is only reason of switches no operation in this camera.
Feb 03, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Button don't work
Nov 12, 2007 | Fuji FinePix A310 Digital Camera
None of my buttons work
It sounds like the "button" circuit board is not working and will have to be replaced.
Sep 03, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Fuji FinePix S5000 stuck in date/Time mode
Set date and time and camera should work. If camera asks to have date set everytime you take batteries out then the memory 3 volt battery is flat ... replace.
Jun 08, 2007 | Fuji FinePix S5000 Digital Camera
Apr 24, 2007 | Fuji FinePix S3000 Digital Camera
Fuji FinePix F470 Digital Camera Logo
64 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
