Replacing the fuser will fix that. Or if you want to strip it down check the lamps and if they are ok change the thermistor and thermostat. But your better off just replacing the whole unit'
C6000 is usually cause by fluctuation of current(power supply).
STEP 1:
Open top cover then turn ON the machine,press System Menu then scroll down to Service Setting,then HOLD BOTH the "Start key" and "#" and press "OK".
Scroll down to Maintenance Mode then press "OK".
press 163 on the keypad
scroll down to "Execute"
press "OK"
Turn Off/On...
If C6000 appears again..,
STEP 2:
U have to reset the fuser thermostat manually.
FUSER REMOVAL:Remove rear cover,top cover,left and right cover.
Remove two screws. Unplug two connectors. Pull out Fuser unit.
Thermostat removal:
remove two screws,separate the upper part from the lower part,,
remove separation claws (3pcs each 1 held w/ screws at the rear)
remove the heater lamp,and upper fuser roller...
remove two screws that held the thermostat (circular shape)
(reset manually)
If you touch the top of the thermostat you will notice that it is in concave form...,you have to drop it hard on the flat surface in order to bring back it\'s original form which is CONVEX.
Error C6000 related to fuser unit, you can try to reset to see if it works, other wise you need to replace fuser unit.
try to reset following these steps:
press on the panel the key 1078 1078, this will take you to maintenance mode.
now hite the key 163 And then hit the Start key.
select Execute and press Start key again.
Turn the machine off and on.
C6000, С6030 is Abnormally high temperature in the fixing section – The fixing unit
thermistor output voltage remains less than 0.5 V for longer than 1 s,
indicating the fixing temperature rises above 536F this may be the fuser is no good. Sorry? coll to Servise center Mita. Dood lack!
Go into the service mode ( 10871087 ) then enter 163 then hit the start button. This clears the C6000 (heater error) and if it is a false code due to a power outage, it will clear the code and resume normal operation. If the code comes back, you likely have a bad heater lamp or thermal fuse or thermistor.
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
First open top cover then turn on power. press system menu/counter arrow down to service press and hold start, # then enter keys arrow down to maintenance press enter arrow down to Sim 163 press enter select execute press enter turn off power then back on
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
try this. enter "10871087" from keypad. you should now be in maintenance mode. enter "163"press "start or print" key. you should see a screen that says "execute" or it may say "reset". cursor or highlight "execute" and press "start" key. now press "stop/clear" once or twice. then press "01" then "start" to exit maint. mode. very important!! as soon as you press "01" and you see "please wait" open your front door. wait 2 secs, then close door. that should get you going unless there is a true failure. good luck and you may want to write this procedure down as it may happen sometime again.
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
This is a fuser problem -- here is a reset method:
press enter
press enter
select execute
press enter
press enter
press enter
select execute
press enter
