SOURCE: lid lock stays on and constant beep on excellence washing machine
I am having the same issue and hope someone can post a solution. I have found a work around though. Mine does it when it is on a 'Regular' wash cycle, I found that if I put it on Permanent Press it works fine.
SOURCE: Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Hi
The issue is with the lid switch-lock assembly that is bad
and should be replaced. Hope this helps...please post back for further
assistance.
Daniel
