What can i do 2 try and fix this camera not that old and hardly been used the shutter is jammed so there for i cant take pictures
SOURCE: Kodak Z760 Digital Camera....shutter button is JAMMED...HELP!!!
if it's only the shutter buttonl you can send it in to kodak service center;; THAT'S THE ONLY CAMERA COMPANY THAT HAS GREAT SERVICE; I should now I have this camera; after one week of having it my sister dropped it and the speakers didn't make any sound at all; I call kodak they gave me an address i send it in in a tuesday and by saturday I had it back fixed ;; for free;;; well it was in warranty.. if yours still has a warranty call them;;
SOURCE: Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
SOURCE: Pictures too dark. Shutter operating too slowly.
Are you in auto mode? If it is manual then it is possible that the settings are not correct for the light. You can look at the meter to see what the camera thinks about the exposure.
It sounds as if your subject is too dark. Does this happen when the area is brightly lit? Does the flash fire?
SOURCE: Lens and shutter jammed
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
