Good Morning Louis,
I see that you are having trouble with your Frigidaire top load stacked washer and dryer, model# FEX831CS, not getting any water into the tub even though the agitator is moving. There are a couple of things we can try.
1)Make sure that the water is adequate in the area where your laundry center is located. Check another faucet in the house. Wait until the water supply and pressure increase.
2)Make sure the water supply faucets are completely open. Both the hot and cold.
3)There could be water running elsewhere in your home. The water pressure must be at least 30 PSI going into your washer. Try to avoid running water elsewhere while your washer is filling.
4)Make sure that the water inlet hoses are not kinked. If they are, straighten them out.
5)Try selecting a larger cycle for your load size. This might show the water coming in more.
6)Make sure that you have not overloaded your washer.
If you have tried all of these with no success, try resetting your washer by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. Once power has been restored to your washer, try running any cycle. If you are still having trouble with water not coming into your washer, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine what is causing the water to not enter into your appliance. Hope this is helpful.
-Best Regards-
WP
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
