Started to fill with water and this F50 code appeared. Cleared it two separate times and it still comes up
SOURCE: code f50
It has a faulty control board. sorry but this a bad part from the factory. There is class action lawsuit against whirlpool about it. Call and complain and then maybe they will pay to fix it.
SOURCE: whirlpool cabrio model wtw6200swz, desplays fault code f50
make sure the basket is "free" floating. F50 is a stalled motor read. This really neds to be serviced by a technician.
SOURCE: My Whirlpool Cabrio WTW6400SW2 has a F50 error. I
LOOK ON WIRLPOOL.COM AND LOOK UP CODES HIT THE CLEAR BUTTEN FOF35 SEC
SOURCE: Whirlpool Cabrio Model WTW6400SW2
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^&
