Sanyo DP42849 42 in. HDTV Logo
Dan Grimes Posted on Apr 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sanyo dp42849 completely black screen, green light blinks every minute.
Hi there, I have a sanyo tv. I went to turn it on today, the green light came on but the screen is completely blank. The green light stays on, but blink about every 40 - 60 seconds. Then remains on, blinks again. And Thats all it does. Any solutions :( I've seen alot of responses of people with "constant blinking green light", but mine the light only blinks one time every minute.
Level 3:
Top Expert:
  • Sanyo Master 76,851 Answers
  • Posted on Apr 27, 2014
Sanyo Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987081
Points
237762
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
5 Related Answers
Anonymous
  • 71 Answers
  • Posted on Mar 05, 2009
SOURCE: sanyo 42" flat screen tv green light comes on but no picture
oops u r in trouble.
Justin Smith
  • 135 Answers
  • Posted on Aug 23, 2009
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Anonymous
  • Posted on Oct 11, 2009
SOURCE: TV blinks and then no picture at all
HOW DO YOU CHANGE A LAMP BULD IN A SONY HDTV. MODEL#KDF-E60A20
Anonymous
  • 183 Answers
  • Posted on Feb 28, 2010
SOURCE: My new Sanyo HDTV LCD won't come on, although the on light is on.
If your Tv is in warranty or you have a cover plan, you need to return the Tv for repair or replacement.Your Tv sounds like it has a power supply fault.
Chi Chu
  • 8457 Answers
  • Posted on Apr 02, 2010
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sanyo tv Dp42849 Hey guys hru, my tv went black last night and the green solid light is blinking now. I did some research on but not so savvy on tv things. I pulled the plug and plugged back in the screen...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://elektrotricks.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right side. Some models of Sanyo TVs uses Philips circuit board.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
I have a sanyo tv model Dp42849 it won't turn on. Little green light comes on but has a black screen.is there a reset button on the tv somewhere
Step 1 Press the "Power" button located at the top of your Sanyo remote control to turn your television on.
Step 2 Press the "Reset" button located next to the power button.
Step 3 Press the "Reset" key a second time to reset your Sanyo television and restore its factory settings.
Should you require further assistance. please reply to this directly
Thank you.
2helpful
Sanyo DP42849 no picture but has sound
Sounds like an inverter problem. On some of these sets, the inverter and the power supply are on the same board. These boards tend to be quite pricey, $100 + range. I've worked on your particular model with the same problem, and it was a bad inverter/power supply board. I would recommend you get a diagnosis to be sure.
I have a sanyo dp42849. i turned it on this morning. the power light went on and i have no picture or sound
Sounds like a main board issue, but please have the set diagnosed properly. Be aware, some Sanyo main boards can be hard to find and costly !!!
9helpful
4answers
Will not come on it worked fine earlier.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
2helpful
I have a 1 year old sanyo 42" lcd tv, model DP42849, The tv was running perfect till one day watching a movie, the screen went black and audio went all strange, i shut it off and on, and nothing, the power...
You need to find out if the power supply is putting out 24vdc for the backlight inverter board, it can be that the inverter board has short circuits which will cause the 24vdc to go into shutdown to protect itself, you can disconnect the power cables to the inverter board to see if you will get the 24vdc back.
39helpful
4answers
Hello my Sanyo dp42849 42 inch has no picture and no sound. when i turn on the tv a green light in the bottom right hand corner comes on and occasionally flashes off and then back on.
First, you need to know the sub-model of your TV.
It is called "chassis" and is shown on the back of the TV on the label where the model number is shown.
For example it can be "P42849-00" or "P42849-01".
Then search at www.coppelltvrepair.com/search or just go to www.coppelltvrepair.com and enter the link for SANYO DP SERIES to search for that.
Here's an example of a repair service (note it may NOT be the one for your exact model though!):
http://www.coppelltvrepair.com/p/41/sanyo-dp42849-p42849-00-does-not-power-on-repair-service
Hope this helps!
3helpful
Sanyo 42" LCD will not turn on!!!
Power supply board is dead.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
2answers
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
