Why won't my Jensen MCD 9424JA Marine AM/FM Stereo Receiver/Compact Disc Player eject a CD?
When I push the eject button on my MCD 9424JA Marine AM/FM Stereo Receiver/Compact Disc Player the CD will not eject. The machine just buzzes. The CD works otherwise.
Hi. I would contact Arcam directly for this - there may be a reset action you could perform or they could diagnose the fault further.
HTH http://www.arcam.co.uk/advice/contact.htm
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Had the same problem. It's the microswitch/eject button-reset. The wires were-soldered.works fine.you actually have to remove the switch to inspect the soldering.
I think you have a mechanical problem with the load and eject mechanism. Either a spring or a gear has popped out of place or may be a switch got stuck and malfunction. If you are mechanical incline just open the unit up and look for anything that look out of place, becareful and remember what goes where so you can put it back in order. That is how I fix mechanical problem. Good luck.
