Turn the ignition switch to ACC or IGNITION, press the function switch until time (hour and minutes) is displayed. Press and hold the function switch for five seconds or until 12HR begins to blink in the speedometer display window. Then release the button. THEN press and release the function switch once to advance to a blinking 24HR or military style time display. Then each time you press and release the switch, the display will change from 12HR and 24HR. When the desired time is displayed, press and hold the function switch for five seconds and the display will switch to the time display with the hours blinking. There is NO AM/PM setting. Press and release the function switch repeatedly to advance the hours to the hour you want. It will advance by one hour with each press of the switch. WHEN the desired hour is displayed press and hold the function switch for five seconds and the minutes display will appear and blink. THEN press the function switch repeatedly until the desired minutes display is attained (the minutes value will change by one minute for each switch depression) and then press and hold the function switch for five seconds and the minutes display will stop blinking which indicates that the time has been set. Turn the ignition switch off and the time you set has been saved and will change as time passes.
SOURCE: Turn signals, break light and
It can be problem with fuse , under the seat.May be any of the fuse is blown and causing this problem.---- Or any of the wire is got pinched under the seat or towards Handel bars.------------ To test this voltage has to be checked from ignition switch.---- For testing procedure, click the link below :----- http://howtobyme.blogspot.com/2011/08/turn-signals-brake-light-and-horn-not.html -------------- This should help.thanks.Helpmech.
