Another possible reason why your Kenmore Elite Oasis dryer model 110.67042600 won't start is because the door switch is defective. The door switch is located on the door of the dryer. To check the door switch: 1. Unplug the dryer from the wall outlet.
2. Open the door of the dryer.
3. Locate the door switch on the door of the dryer.
4. Use a multimeter to test the door switch for continuity.
If the door switch is defective, it will need to be replaced.
Since the door lock/switch assembly has been replaced yet the problem persists, the problem, therefore, is either with the wire harness connecting the assembly to the central control unit (CCU) or the CCU itself. Check and make sure the door strike, the one that activates the door switch, in intact and tightly installed.
Check the wire harness connection between the door lock/switch assembly and the CCU. Make sure the connectors are clean and snugly fitted both on the door lock/switch assembly side and the CCU side and that the wires are intact. Replace the wire harness if anything unusual for a good connector is found such as spark marks or corrosion. This is the simplest and best way to verify the condition of the CCU. If both the door lock/switch assembly and the wire harness are replaced but the problem persists, consider a faulty CCU that needs replacing.
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
These are symptoms of a broken door lock and switch assembly and the only viable solution is replacing the said assembly if no issue is found with the wire harness connections. The machine will not advance to the spin cycle unless the door lock spin switch is activated. This is a safety feature to prevent the door from opening and avoid injuries during the high-speed cycle. Replace the door lock and switch assembly and it should solve the problem. Click on the link below for the detailed instruictions on how to replace the door lock and switch assembly. The part number for the door lock and switch assembly of your machine may be different but the instructions still apply.
Turn
off the power to your Kenmore dishwasher before attempting any repairs.
If you have a portable Kenmore dishwasher, you can just unplug the
power cord from the wall. Built-in dishwashers are hard-wired into the
cabinet, so you will have to turn off the breaker switch at the home's
circuit breaker box to cut the power.
Remove
the screws that hold the kickplate onto the lower front of the Kenmore
dishwasher. Take the kickplate off to access the door springs.
Check
the door springs to make sure they have not come loose from the door
support or the adjustment holes on the dishwasher. Re-attach any ends
that have slipped off their connections.
Replace
the springs if they are connected at both ends but still do not have
enough tension to support the weight of the door. Once a Kenmore
dishwasher door spring is stretched out, it cannot be restored to its
original condition. Unhook one end of the old spring from the
adjustment hole. Unhook the other end from the door support and discard
the spring. Insert one end of the replacement spring into the
adjustment hole and the other end into the hook on the door support.
Open
and close the door a few times to make sure the spring is now working
properly. The door should not bounce up and down or sag on the hinges
when it is in the open position.
Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Door switchIf
the door switch or the door-switch actuator is defective, the dryer
won't work and you need to replace the failed component. The switch is
inside the dryer main housing near the door frame. Sometimes you need
to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
