Got main part of power supply going, c902 burnt, and inverter ballast for the lamps seem burnt, need value for c902 before I can move on
SOURCE: "failure of "cold-cathode-fluorescent-lamp"
they can be repaired by an electronic tech but are cheaper buying a new one. The cost of new inverters range from 30-80$ USD. Viewsonics don't cost that much and now you can get 18.5 inch widw screen acer or other brand lcds for 89$.
i woudl really suggest just buying anew unit.
SOURCE: suspect backlight inverter circuit--desktop appears completely for 1s and then loses backlight
"Latched Open Lamp Protection Pin 4", disconnect the transistor 7002 "D" Pin on BIT3105 Pin 4.
SOURCE: Viewsonic VG2021m does not work. I took it apart
I just work on one of this last wek with the same symptom, it turns out to be the logic board problem, not available any where.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2021/
SOURCE: i got some burnt resistors on my acer al1717f
One of these service manuals should match your chassis: Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1717&kategoria=monitor&kat2=all
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
