Good Afternoon Donna,
I see that you are wondering what an error code 41 is on your Frigidaire washer, model# GLTF2940ES. Error code 41 means the control board thinks the door switch is open. You will want to make sure the door is closed. Reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker. When you restore power select any cycle and start it. If you are still receiving an error code 41, I suggest contacting your local authorized technician. Hope this helps.
-Best Regards-
WP
DTC - 41 MEM- CAL error
DTC - 41 Cam sensor sinal error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS System error
I hope this is helpful
