Re: How do i hard reset supersonic sc 1007jb tablet?
Step 1 with it powered off Press and hold the "home" button (the only other button) While still doing step 1 press and hold the power button releasing the power button when the first slash screen appears Release home when recovery boots
Hello, today I will show you how to fix stuck on android or remove password, for model SC-91JB - SC-74JB
First, connect your tablet to PC.
you need drivers to be able to reset;
download the adb drivers from website; www.adbdriver.com/downloads/ or click on link below for direct download. ADB Driver Installer (9.22 MB) next, install the ADB driver then you will see a USB root on notification area on your PC.
next, download the fastboot click on link below; https://www.dropbox.com/s/adu0ysny2191kgd/Fastboot.zip?dl=0
install fastboot and you will open a dialog box.
Follow the steps on image below; step one, two and three...
next, command prompt will open and you need to type these commands;
This will reboot and erase password.
If stuck on Android; type commands below (it's the same way like on top image just shorter commands).
Most tablets are minimal for content. There are some good resources on the Internet that will answer your questions. Here is an example of one that came up with a google search on ' how to use android tablet ': http://www.dummies.com/how-to/consumer-electronics/Android-Tablets.html
To do internet you need:
1. browser
2. wireless internet connection with
2a. login access. (some places don't require this)
Look at the wifi signal indicator. If the signal is too weak the internet won't work.
(Or you may have it turned off. Go to Settings, find WiFi, and make sure it is on.)
When the tablet is OFF hold volume up button then switch on all the time holding the volume up button untill it boots into reset options. use vol up and down to scroll between options then power button to select.
