The washer will only stop for 10 minutes and then continues. How do I soak clothes for longer than 10 minutes without the cycle beginning again?
SOURCE: WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
SOURCE: Spin Cycle Not Working
the most common problem when this occurs is the lid switch has broken inspect it if not click when lid is closed replace the switch you see if you can get local it saves some shipping cost unless they are outragious then order on line
SOURCE: F28 appearing on display. What does it mean? how
Check your washer plug to see if the connections are
tightly
screwed. Next check your filter if you haven't for long.
Remove
the 3 screws at the bottom of the front panel under the
washer door. Your filter door will be light brown. If you find a hose
there it is to drain out excess water (water that could not be drained
by your pump) After you hv drained unscrew the cap and
remove all the junk inside. Have a large plastic bag to catch junk and
water. Refit carefully after cleaning out. If not solved, something
shd be blocking your pump, check this out
How abt a nice rating
for the free help? Thnks
SOURCE: Does the Model #WTW7340XW2 Whirlpool clothes
Hello, After looking at your service book no it should not fill untill it starts the cycle. Sorry...If this helps please rate me. Thank You :)
