Tried to move the tv and the stand cracked and now wobbles. I need to find a replacement ASAP
SOURCE: Samsung 4235X/XAA older Plasma TV Need to take the base out for m
GENTILITY lay that set face down on a table covered with a thick blanket. There should be 4 long threaded bolts near the bottom that fasten the legs of the stand inside the framework of the set.. Remove these and the stand should slide right out.
www.mcveyelectronics.com
SOURCE: How do you the base stand on the Samsung T220?
I tried to pull the base stand out - no luck. I tried to wedge a screw driver in - no luck and it looked like the screwdriver could damage the plastic if pushed harder. I finally used a wide metal paint scrapper. It went in where the screwdriver would not go and moved to base enough to allow it to pulled out the rest of the way.
