SOURCE: fisher and paykel washer gwl 11 us
ok You have a blown Motor controller module. There could also be another fault that caused this to blow up. eg a faulty drain pump, lid lock or Diverter valve, inlet valve. you'd need to use a ohm meter to test all these. cheers
SOURCE: fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
SOURCE: when the washer (fisher & paykel gwl 11) goes into
Try unplugging the washer to reboot the curciut board. Leave unplugged for 5 min. Then replug and select only one setting. Multiple setting selected in a short period on time will confuse the little brain in the board. Reboot to fix. Be patient!
SOURCE: Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
SOURCE: fisher & paykel washer will not function
Dear Everett649,Sounds like to me you have an issue with the motor, having said this, it could be due to the timer/ programmer. Firstly, if it was me, remove the metal panels that give you access to the motor, and then disconnect the wiring for the motor, and remember which way they go (I take digital pictures first of where the wires are). Then remove the brushes and replace them if they are worn. . . or replace them anyway.If this doesnt fix it, then the problem is likely to be manifested in the programmer/ timer, and this is where costs start to increase.
I hope this is the fixya for you, but in the meantime, please get hold of me on here if you feel like you have further questions or have comments.
Yours sincerely
Ouszen
