Underhood Electrical Center or Junction Block Replacement
Removal Procedure
- Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
Click to Enlarge
- Disconnect the positive battery cables from the underhood fuse block terminals.
- Remove the tape from the wiring harness at the base of the underhood fuse block base.
Click to Enlarge
- Release the underhood fuse block(s) clip retainers using a small flat-bladed tool.
Click to Enlarge
- Remove the fuse block(s) and wiring harness lifting up from the base and reposition from the base.
Click to Enlarge
- Remove the nuts from the underhood fuse block base.
- Remove the underhood fuse block base from the shock tower.
Click to Enlarge
- Remove the underhood fuse block lower front terminal positive assurance retainers using a small flat-bladed tool.
Click to Enlarge
- Remove the plastic shields from the battery cable and buss bar terminals, using a small flat-bladed tool to release the clip retainer.
Click to Enlarge
- Remove the bolts from the buss bar jumper bar.
Click to Enlarge
- Remove the buss bar jumper bar from the fuse block(s).
Click to Enlarge
- Remove the fuses from the fuse block(s) to access the buss bar terminal release tabs.
Click to Enlarge
- Remove the buss bar(s) from the fuse block(s) using a terminal releasing tool, and pulling down and out on the buss bar.
Click to Enlarge
- Remove the buss bar(s) from the fuse block(s).
Click to Enlarge
- Release the clip retainers from the underhood fuse block(s) battery cable and buss bar terminals using a small flat-bladed tool.
Click to Enlarge
- Remove the underhood fuse block(s) battery cable and buss bar terminals from the fuse block by pulling down.
- Remove the fuse block and lamp wiring harness from the vehicle, if required.
I copied the info from my database, sorry, it is read only, The way I copied it, read only, no pictures.
