Kohler customer service has provided a free seal (yellow) to replace the original seal (red)on the bottom of the Aqua Piston. The yellow seal is a big improvement over the red seal, but the toilet tank still leaks. I am ready to return the toilet to Home Depot.
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
The two most common causes for leaking pumps are worn out seals or leaky gaskets. The seal can be replaced and the pump can last for a long. The same thing can be said for a leaking gasket. I don't know what parts are available but many pumps can be assembled after buying all the parts. It is just higher priced.
If you are mechanically inclined you can do either of the above jobs but it best to watch someone else do it first. If you bring your pump to Leslies pool supply when they are not very very busy they can usually repair it while you watch.
